Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 07-02-2004, 02:59 PM
ReddragonDC2 ReddragonDC2 is offline
breaking in the spring
i purchased a tokico illumina strut and spring combo for my 97 integra ls...they claim a drop of about 1.5 in. in the front and rear. so my question is that after i installed them, only the front got dropped an inch and the rear stayed at stock height. does it take time to break it in?
also, when i installed them, i didn't line up the bottom of the spring with the strut...as in about a 1/2in. away from where it is suppose to rest, will it slide in as time goes by?
then when i went to drive it, the abs light stayed on...whats up with that?
Old 07-02-2004, 07:44 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Typically it takes some driving around and a couple weeks for the combo to "settle in" and get any sag in it that it'll get. It shouldn't sag more than 5mm from when you installed it though.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 07-03-2004, 07:34 PM
BullShifter's Avatar
Re: breaking in the spring
you should install the spring correctly.
Old 07-04-2004, 02:49 AM
Re: Re: breaking in the spring
should i re-install it then?
Old 07-04-2004, 10:59 AM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
Jack up the car and look at the assembly to make sure they're resting in the right place...
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 07-04-2004, 01:54 PM
i did this morning and they are not. as in where the bottom part of the coil is how it should be resting on the strut..there is still a gap, but it has only been three days since i installed it.
Old 07-07-2004, 10:35 AM
boosted k20's Avatar
boosted k20 boosted k20 is offline
REINSTALL them. make sure that the bottom of the spring lines up with the lower perch on the shock. u might need to compress the spring to do this, or do what i do:
i jack up the car and place it on jack stands.
for the fronts:
place the jack under the lower control arm and jack it upon the LCA so it compresses the spring a bit . then open up the hood, and loosen and remove the center 14 mm nut on the shock shaft. when u remove this nut, lower your jack slowly. this will make the springs come loose from the shock. now set the spring on the proper location on the shock (make the bottom of the spring flush with the end of the bottom perch on the shock).
once u do this, guide the shaft of the shock through the hole in the engine bay while u jack up on the LCA. once it through this hole, tighten the nut onto the shock shaft. now your done.
this is how i do my suspension. i dont use any spring compressors and i dont have to remove the whole shock assembly from my car. it's much faster than removing the whole shock.
www.MEDIUMRACING.com
