Old 07-02-2004, 01:33 PM
mooneybeams mooneybeams is offline
1999 Accord Headlight not working
My passenger side low beam was out (high beam worked fine). Husband replaced the low beam bulb, now neither beam is working on this side. He says it is not the fuse. Any ideas? Thanks!
Old 07-02-2004, 01:39 PM
HONDA_99 HONDA_99 is offline
Re: 1999 Accord Headlight not working
check relay, check the voltage at fuse.
Old 07-02-2004, 01:55 PM
Re: Re: 1999 Accord Headlight not working
OK, stupid question but how do I do that? Thanks!
Old 07-02-2004, 02:13 PM
to check voltage you need to have miltimeter that measures DC voltage.
your car separete circuits for left and right headlight so you can swap relay from driver side (working one) to passenger side, and see light is working.
not sure where relay located on I4 models, but on V6 models relays are in under hood fuse box.
Old 08-29-2004, 11:18 AM
Natedawg241 Natedawg241 is offline
My 99 accord passenger low beam dosn't want to turn on alot either....for now untill i get around to fixing it....i just go up to it and hit it light and it cuts on... :/
Old 08-29-2004, 11:30 AM
Turns out for me husband is just an airhead...I had my Dad change the headlight and it worked fine! You can always depend on your daddy...!
