Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 07-02-2004, 12:07 PM
c0052090 c0052090 is offline
Unhappy Passat Passenger SIde Lock
Hey Guys,
Need your INPUT once again.. Go a 99V Passat and whenever I try to use the in-car controls for the central locking, the driver side lock keeps poppin out (unless I press it quickly twice)>>!!
I have tried getting the lock inside the door changed.. NO LUCK
I have also tried changing the Central Door Locking Unit (Brain thingy) that is located underneath the carpet at the front (passenger side).l And you've guessed it .. it didnt work>!!!
ANy ideas would be brill..
Thanks Guys./.
Paul
Old 07-02-2004, 07:17 PM
boschmann boschmann is offline
Re: Passat Passenger SIde Lock
Does it lock itself properly after you reach about 10 mph? Does it lock properly if you lock it with a key in the passenger side door lock? What I'm wondering is if it is a vacuum leak problem which would cause it to happen when locking by all methods. Or, just from the one switch, in which case I would suspect the door module (as you already replaced the main module).
Old 07-05-2004, 11:54 AM
WHen i Lock with the key from either side, it locks, no problem. WHen I lock using the inside controls on the driver side door, it jumps out!!
ANy further ideas?
Thanks In Advance
Old 07-06-2004, 10:08 AM
I'd first suspect that switch. Otherwise, do you have access to a door lock module that is in the door? It's part of the power window motor assembly.
Old 09-29-2004, 03:39 PM
jtsillas jtsillas is offline
Mine is a 00 V6 GLX wagon.
I've had similar problems with the passenger side lock.
In my case it will often fail to pop down all the way at the
10 mph mark or will not pop down with keyless.
I live in a safe neighborhood so it doesn't bother me
too much
If someone can tell me how to disable the annoying
10 mph auto lock down, I would appreciate it.
Old 10-08-2004, 12:19 AM
bleedvw bleedvw is offline
jtsillas
the auto lock can be disabled by your local dealer.
Old 12-17-2004, 01:38 AM
diesel_uk diesel_uk is offline
open door spray contact cleaner into lockling meck ( inside door) if that does not sort it then open door assembly replace vacum actuator. ( my spelling is very good i know )
[IMG]://www.webphotos.com/viewphoto.asp?mi=1&smi=1&a=75015&p=1638698[/IMG]
My advice is worth every penny you paid for.
