Old 07-02-2004, 10:20 AM
braddenn braddenn is offline
Brake fuse blowing
The fuse keeps blowing and I can not find the short. The Cruise Control is suspect (because it has not been working for a while) but I need help in where to disconnect it. Any suggestions appreciated.
Old 07-05-2004, 10:11 PM
mwt mwt is offline
Re: Brake fuse blowing
What year car?
Old 07-21-2004, 12:06 PM
Jeffi Jeffi is offline
I had a whacky fuse problem for a while on my 93 Taurus. Turns out the cigarette lighter was stuck. Wouldn't it be great if that were the answer?
Jeff
Old 07-21-2004, 01:17 PM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
Under what conditions does it blow? The moment you put it in? Or only after you hit the brake pedal? And what year of car?
Check your bulbs. I had one filament on a two filament bulb that when it blew, just broke on one side and then layed across the second element.
The parking lights would work, and the signal lights would work in the daytime. But as soon as I turned the headlights on and then signaled a left-hand turn, the fuse would blow!
That was a real MOFO to figure out.
Old 07-23-2004, 10:07 PM
Froze_Tread Froze_Tread is offline
Send a message via MSN to Froze_Tread
Ive seen the windstars not a toures yet for sure where the Cruise an the brakelights are to seperate circuits on the brake switch and the cruise control side kept blowing the brakelight switch side. Usually its the connector to the switch going bad but sometimes it was the actuall switch. Drives most technicians nuts because they dont realize their not on the same brake light switch circuit like most cars are.
If Fords didnt break all the Time i would be out of a job and a few million other Ford mechanics. Just like the Firestone incendent.
