Old 07-02-2004, 08:48 AM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
weird starting problem
i have a very weird problem it seems that every morning i go to start my car and it won't start then if i let it sit for 15 min it starts and works fine all day just every first time that day like the starter makes kinda of a wierd noise mabye its b/c its new and needs to be broken in?
Old 07-02-2004, 09:15 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: weird starting problem
sounds like a defective starter, it shouldn't make any weird noise.
Old 07-02-2004, 12:58 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
you might have to shim the starter
Old 07-02-2004, 07:53 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
with a wait period???? sounds like a vats problem
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-02-2004, 10:04 PM
vats? is that vaccume?
Old 07-02-2004, 10:28 PM
Dober89 Dober89 is offline
vats is the ignition interlock security feature. If your car has it there should be a little black pellet in the key and the car wont start without it.
Old 07-02-2004, 10:29 PM
But vats only started in 1989 and you have an 87 right?
Old 07-02-2004, 10:32 PM
yeah and i got the old skool keys the little circle one fopr the dpoor and the square one for the ignition
Old 07-02-2004, 11:34 PM
89IROC&RS's Avatar
is there a black pellet in the ignition key??
Old 07-03-2004, 07:07 AM
nope
Old 07-03-2004, 01:31 PM
89IROC&RS's Avatar
not vats then, muh bad
Old 07-04-2004, 12:03 PM
73'Camaro 73'Camaro is offline
It is possibly something simple. Get a battery terminal cleaner and clean up your battery terminals and the terminal clamps, also check the wires that connect to the starter maybe they are not tight enough.
Old 07-04-2004, 12:08 PM
also, if the sound is a clicking sounds it is the dirty cables or loose wires. If the sound is like a minature kawasaki engine reving up, then your flex plate or flywheel is has some ground up teeth or the starter is defective and dosen't engage all the way. I've got to get off the comp now and go to the lake. Have a great 4th everyone.
Old 07-04-2004, 12:54 PM
well what i did this morning seemed to work i turn the key all the way so there was power (but not so it turns the engine on) then i pumped the gass 3 times like 1/2 way then turned on the car and it worked fine i was thinking mabye if i tried priming it like a lawnmower it will work and it did woot
Old 07-04-2004, 01:04 PM
Ahhh, Genius. Well, if it farts up again try that stuff. L 8.
