Old 07-02-2004, 08:36 AM
Two_Sheds Two_Sheds is offline
Noise problem
For about a year, my current stereo/speaker setup worked perfectly. About a month ago, it stopped. This is what I have:
My Stereo: JVC KD-S790
http://www.sounddomain.com/sku/JVCKDS790
My Speakers: Roadmaster 5.25" 3-Way
http://www.walmart.com/catalog/produ...A96481%3A38981
Here's the current status: The speakers on the left side of the car sound terrible. Static, scratchy bass, a squealing sound when I turn on the car. The speakers on the right sound perfectly fine--until I turn on the ignition. Then they get scratchy and staticy-sounding as well. All speakers are wired correctly, as is th head unit. I've had alternator whine suggested, but it really doesn't fit the description (high-pitched whine that varies with engine acceleration). I've checked for shorts in the speaker wires (none), and grounding issues (none). The head unit and speakers all are in good working order.
Thanks in advance for any advice, guys!
Old 07-02-2004, 08:41 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Noise problem
You blew the speakers... I am surprised they lasted that long.
www.thezeb.com pick up some CDT coaxs
www.cloudcity.deviantart.com
Old 07-02-2004, 11:11 AM
No, I did not. In fact, two of the speakers are brand new, as I bought them because I thought that was the problem. Now, if I put them in the left side of the car, they sound bad. If I put them in the right side of the car, they sound perfect when just the power is on, but scratchy when the ignition is started. As I said, the speakers that I have in there now are all in perfect working condition. As an added test, I wired them up to a friend's car and they work great. It isn't a speaker problem.
Old 07-02-2004, 02:46 PM
MStout's Avatar
MStout MStout is offline
Re: Noise problem
Only obvious sounding thing would be the headunit then.
Old 07-02-2004, 03:17 PM
Haibane's Avatar
Re: Noise problem
Headunit is screwed, I agree. Run new wires... Wires might be bad... I guess you check for shorts, so your only option is new headunit.
Old 07-02-2004, 06:47 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
check the wiring.. then the head unit
Old 07-03-2004, 07:43 AM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
Re: Noise problem
You do need to check the wires. But a problem like this might not be something you can find by check the wires. Disconnect the power and ground from the radio. Run both wires and ground wire directly to the battery. If the nois is still there check speaker wires for a short. If there is no short you are going to most likely need to change the radio. Would not hurt to take a test speaker and hook it directly to the radio either. But I think your problem lies in the power and ground wire.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
