Old 07-02-2004, 12:34 AM
L36er L36er is offline
low coolant light
I have a 99 gt and the coolant light is blinking about 2 or 3 minutes after starting. I have checked the fluid level and there is the correct amount in there. Any ideas?? Bad T-stat maybe??
Old 07-02-2004, 11:09 AM
stan_5150 stan_5150 is offline
I've got a 2000 GT with the same problem. Take a look at the Low Coolant module which is located right below the radiator fill cap. I haven't changed mine yet but plan on doing that this next week. Hope this helps.
Old 07-19-2004, 04:57 PM
swallow swallow is offline
Re: low coolant light
Look for dark gray sludge inside the radiator neck or on the bottom of the radiator cap -- if present -- consider blown head gasket or cracked head.
:-( cws
Old 07-19-2004, 05:40 PM
BIG-L's Avatar
BIG-L BIG-L is offline
The Coolant level sensor is located about half way down from the radiator cap and it could have some sludge on it from the great Dexcool that GM uses ...... you may try tapping lightly on it with the head of a screw driver and see if that helps or you may want to pull it and check the sensor for sludge,if thats not it its time to replace it for about $40.00.In the pic below you can see the inside of the sensor and how it may become clogged from the Dexcool..........~Larry~
ClubGP Member 6530
Since 2001
Old 07-21-2004, 09:43 AM
MoshimoGTP's Avatar
MoshimoGTP MoshimoGTP is offline
Send a message via MSN to MoshimoGTP
I agree with BIG-L, that was my problem too... clean it or repace it...
RED 1999 Grand Am GT - RAM AIR V6 H.O., 4drs, sunroof, and more!
Old 07-21-2004, 10:55 AM
stlwagon stlwagon is offline
And ditch the dexcool! Flushed mine and refilled with good old Prestone. Don't care what GM says.
