Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 07-01-2004, 09:42 PM
snakesbee snakesbee is offline
Angry Dome light leads to disaster - HELP!!!
Ok, so my dome light is flimsy and I went to make the connection better by turning it just a bit. Sparks flew, and the fuse blew. Now I replaced the fuse but a) clock does not work b) interior lights dont work c) dome light does not work d) "left your lights on" warning chime, does not work. Nissan wanted 80-280 dollars to just look at it. Anyone have any experience or any idea what it could be? help.
Old 07-01-2004, 11:24 PM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Re: Dome light leads to disaster - HELP!!!
Wow. Sounds like you blew more fuses than you think. Did you check them all?
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 07-01-2004, 11:39 PM
Checked most of the ones that I thought "made sense" in the situation. I guess I will go back and check them all just in case since the situation is pretty wacky.
Old 07-01-2004, 11:49 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
yeah, i would check all your fuses. if it isn't that, ummm, could you of blown out your bulbs? wait, you chime doesn't work and that isn't a bulb, so i don't know anything else but fuses.
ZedEx Crew Member #2
Old 07-02-2004, 12:27 AM
If you check all the fuses and still nothing, I dunno man. Never heard of this happening before.
Old 07-02-2004, 01:56 AM
neogenesis neogenesis is offline
You could check your wire just incase something came loose if the fuse check doesn't do it.
Old 07-02-2004, 02:44 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
if it isnt fuses and your still not gettin power. u possibly could ahve shorted out a wire. shit happens...sometimes crazy.
Old 07-03-2004, 05:56 PM
tom_sims tom_sims is offline
check your relays under the hood and see if it damaged any of those. cause all your interior lights and everything you listed it ran directly from the battery. i would also take the dome light off without sparking it and check if you touched the live wire to the ground or the frame. if theirs to much power surging through still touching the frame it will blow the fuse will break everytime you turn it on
