replacing caliber
i just repaced pass. side caliber and i just blead that side it locked up so i got another one and it did the same thing WHAT AM I DOING WRONG do i really need to bleed all four sides also now my abs light is on the caliber is still locked up and i pissed off what do i need to do please asap
Re: replacing caliber
I'm not a mechanic, but Ive always been taught that whenever you bleed your brakes, you start at the tire closest to the Master cylinder, and work out, from there. Always bleeding all 4 brake lines.
As for the abs light, double check your ABS cable line, a few years back my ABS line was slightly cut and I ended up having to replace the ABS sensor unit. I don't know what to tell you about the caliper being locked up. |
driverside-front then passengerside-front then driverside-rear then passengerside-rear as far as the abs light being on once you get the brakes bleed right it should turn off. if not disconnect the battery and reconnect it
Sometimes the caliber isn't at fault at all,try replacing the brake hose since you have a new caliber.Hoses can keep the caliber from being able to release pressure.
