Go Back   Automotive Forums Car Chat > Automotive Art > Remote Control Cars
Remote Control Cars Questions, comments or discussions on the wonderful little vehicles.
Old 07-01-2004, 08:04 PM
Howielong's Avatar
Howielong Howielong is offline
Send a message via AIM to Howielong Send a message via MSN to Howielong Send a message via Yahoo to Howielong
How to paint a body
Some of you never know how to paint a body. So here it goes. This is for the first time body painting guys. And new people to the hobby. I thought it would be a nice addition to the forum are here. And mike stick this.
What You’ll Need - Supplies
Dish soap
Clean cloth or paper towel
Fine steel wood, or SOS pad
High quality masking tape (3M)
Permanent marker
Straight and curved scissors
Sharp hobby knife
Pencil
Lexan compatible paint
Homemade wheelwell template
Window masks, Decal sheet, wing mounting hardware
Step 1: Wash your body
To remove any residue left on the body after molding, you must wash it inside and out. Use warm soapy water in your sink, just as if you were washing the dishes after dinner! Pay special attention to the tight curved areas and corners. Dry the body with a clean towel or hair dryer. It must be completely dry before you paint it.
Step 2: Cut off the wing
If your body came with a wing or spoiler molded into the excess material, you must cut it off. Some wings are molded in the opposite direction of the body. If this is the case you must remove the protective film, and paint the reverse side.
Step 3: Marking the Body Posts
Drop the body over your chassis, and use a permanent marker to mark the position of the body posts. Center the body over the chassis, checking the wheels in the wheel wells, and also the width.
Step 4: Marking the Wheels
While your body is over the chassis, you can also mark the wheel wells. Touring car and on-road bodies sometimes have no rear wheel well outlines, this give you freedom to make a perfect fit for your chassis. A great tip is to make a wheel well template, and use it to trace 4 identical wheel well shapes. They can be made from either scrap lexan, or cardboard.
Step 5: Window Masks
Apply the window masks inside the body, and press down all the edges to keep paint from sneaking under. When the body is painted the masks will be removed to give you clear windows. Use the molded in window lines as a guide for placement of the masks.
Step 6: Scuff the Body
An optional step is to scuff the inside of the body with either fine steel wool or an SOS pad. This will help the paint to stick to the body. Be careful to not scuff to hard, and to also not scuff the areas you want to remain clear. Clean the body of any steel wool flakes.
Step 7: Draw Your Design
Use a permanent marker to draw your design on the outside of the body. Be creative, but keep it simple if you are a beginner.
Step 8: Mask Your Design
Apply masking tape to the inside of the body, covering the design you have drawn. Seal all the tape edges.
Step 9: Cut your Design
Using a sharp hobby knife cut the masking tape along the marker lines. If you cannot see the marker through the tape while cutting, hold the body up to the light, or use a pencil to retrace the design onto the inside of the tape. Take your time cutting, and be careful with the sharp blade!
Step 10: Finish Masking
Once you have the masking tape cut out to your design, peel away the excess. Again check that all the edges of the tape a firmly pressed down. Masking in a dark-to-light painting order will give you the best results, so that no dark paint will bleed through lighter or thinner paint.
Step 11: First Coat
The first coat is really important. Painting a light first coat will seal all the edges around the tape, and will give the rest of your paint a secure hold on the body. Once the paint is completely dry, apply second and, possibly, third coats. When your first color is painted, peel away the masked design, and paint the next color. Use a hair dryer to speed up drying time, and always work in a well ventilated area.
Step 12: Detail It
No it’s time to detail your finished paint job! Apply the decals, and use a permanent marker to outline the windows and other trim details. Cut closely around the headlights, grill, taillights, logos, etc. with a sharp blade or scissors. Also, now you can remove the window masks.
Mount the Body
Use a set of quality straight scissors to trim the lower body lines, and curved scissors to cut the wheel wells. This is where your template markings come in handy. Use a small amount of fine sand paper to smooth the wheel wells, or if you’re pretty handy, you can also use a Dremel tool with a sanding drum.Cut the rear wing/spoiler, and mount it with the included screws and nuts.
Painting Tips from the Pros!
- Use lexan compatible paint only (Recommend brands: Faskolor, Pactra, Tamiya, Alclad II)
- when using spray cans, submerge can in warm tap water for a few minutes before painting. DO NOT heat the can in microwave or oven, and use only warm (not hot) water as paint is highly combustible.
- back light and flourescent colors with white paint, and candy or transparent paint with silver or gold.
- apply paint in 2-3 light thin coats, rather than 1 thick coat
- check all the masking tape and window masks before applying paint to make sure no paint will sneak under anywhere.
- use denatured alcohol or “body wash” products to remove any unwanted marker after you have finished painting. Be sure to not use paint thinner or acetone, as it is too harsh and can damage the lexan.
- take your time, rushing only slows things down in the end!
Old 07-01-2004, 08:59 PM
calvin3's Avatar
calvin3 calvin3 is offline
Thanks Proline
Old 07-01-2004, 09:07 PM
Howielong's Avatar
Re: How to paint a body
Yes that you the god of great bodies. Called PROLINE.
