Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-01-2004, 07:24 PM
JuMBoBeaTS's Avatar
JuMBoBeaTS JuMBoBeaTS is offline
Send a message via AIM to JuMBoBeaTS
confused about offset... help please
ok.. i did a search and did some reading... now.. i have a 2000 civic ex coupe with a stock suspension... recently i picked up a set of 17x7 wheels with 205/40/ZR17 tires... 2-3 weeks after i got my rims... one of the tires got destroyed.. it seems that the inner sidewall was rubbing on suspension components (the spring and the control arm)... now.. i believe the offset of the rim is 42... i looked at the back of the rim and it said ET42...
okay here are my questions
what is the stock offset? my car had steelies...
what is the ideal offset for 17x7 rims for my civic?
would wheel spacers help me attain the ideal offset for a 17x7 rim on civic?? i read that the higher the offset... the more inward it is.. so adding spacers will lower my offset correct??
should i invest in a 4 wheel alignment and camber check once i have the rims reinstalled again??
someone please help me... ive been tryin to solve this problem for a while now.. and its pissing me off.. i have beatiful rims that i cant use... i dont understand whats wrong cuz the front doesnt rub at all... and im not about to rock rims in the front and steelies in the back (unless i go practice drifting lol)
2000 honda civic EX 2dr black
Turbo Future...
Old 07-01-2004, 10:29 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
You got it right about the offset. a 5mm or 10mm spacer should pretty much adjust you from rubbing on the inside. You might need to roll your fenders though if you use spacers. I dunno what the stock steelies offset is, but a typical good offset for Civics is about +38 I personally wouldn't go much higher than that.
And YES, an alignment is a must when messing with the wheels and suspension.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 07-02-2004, 08:50 AM
JuMBoBeaTS's Avatar
Re: confused about offset... help please
if i add a 5mm spacer.. would i need to get longer bolts??
Turbo Future...
Old 07-02-2004, 02:07 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
3mm is about the limit for wheel spacers before you need longer studs. You should have AT LEAST 7 FULL TURNS of your lugs nuts for proper engagement. Anything less and you risk wobbling your wheel off the car.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 07-06-2004, 05:17 PM
THEOLDMAN THEOLDMAN is offline
Here is an offset calculator. The problem with just throwing on aftermarket rims is that as the width increases you must pay attention to the change in the offset. As you found out the change in the offset caused the tire and rim to move inward from the stock wheel position.
http://toy4two.home.mindspring.com/offset.html
Driving the Milano Red RSXTypeS or the White '89 325i listening to Blues & Jazz
Old 07-06-2004, 08:08 PM
JuMBoBeaTS's Avatar
Originally Posted by THEOLDMAN
i would like to use that.. but i dunno the stock steelie width and offset...
Turbo Future...
Old 07-07-2004, 01:21 PM
Re: Re: confused about offset... help please
If you have the old steelies the dimensions should be stamped in the back of them. If they aren't there then you can measure them by using this chart:
http://www.midatlanticmotorsport.com/wheel_diag.htm
If you don't have them check with a Honda dealer parts department, they should be able to tell you. Or you could look it up in the specs for the car by googling it.
