Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-01-2004, 03:42 PM
ponticamatt ponticamatt is offline
blower motor not working on high speed
we have a 1998 se and the blower motor will not work on high, purchased a blower motor controller and installed it, but still no high speed.....any help would be nice
Old 07-06-2004, 01:06 PM
JJ052653 JJ052653 is offline
Re: blower motor not working on high speed
A few people have had blower heater/ac blower problems. It appears that the Heater/ac motor is faulty. If you do a search for Blower Motor you'll see other people have had similiar problems. They have replace the motor and that solve the problem.
Old 07-07-2004, 09:42 PM
randman1's Avatar
randman1 randman1 is offline
If the blower motor works on lower speeds than I wouldn't think that your problem is there. I would first suspect a problem with the blower motor relay or fuse 3 (30amp) in the underhood fuse block (I'm assuming that you do not have elecrtonic climate control). Fan speeds low, med 1 and med 2 go through a blower motor resistor and then directly to the motor. High speed though will trigger a relay and supply voltage through a seperate circuit.
Locate and check the fuse first to verify that it's good. Next, locate and test the relay. I'm using diagrams for a 93 so please check the fuse covers or your owners manual to make sure you're checking the right fuses and relays.
Old 07-13-2004, 12:24 PM
This might help you
Look at the thread, "Heater Blower works intermitently"
Old 07-18-2004, 05:29 AM
markwb's Avatar
markwb markwb is offline
When the blower fast speed relay picks up, it applies full potential (12 +) to the blower motor bypassing the resistor network entirely.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
