Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 07-01-2004, 02:26 PM
pentex pentex is offline
4.3 Vortec
Does a 1995 4.3 vortec fit a 92 4.3 vortec Jimmy?
What has to be changed out?
Old 07-03-2004, 03:12 PM
NJTy180's Avatar
NJTy180 NJTy180 is offline
Send a message via ICQ to NJTy180 Send a message via AIM to NJTy180 Send a message via Yahoo to NJTy180
Re: 4.3 Vortec
there might be some differences, but the swap should still work. Basically there were 2 different types of blocks up untill 1995. the "W" block, which after 1992 was a L35 balance shaft motor and the "Z" block which was a non-balance shaft motor.
The main difference which might exist is the fuel injection setup and the intake manifold, however swapping them over shouldnt be a problem either since the the real "Vortec" engines didnt come out until 1996, thats the better heads were put into production and the bolt patterns and block castings were all changed.
morgan
93 gmc typhoon . 92 gmc typhoon . 93 toyota celica gt . 70 chevy el camino ss
Old 07-06-2004, 08:58 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
The only thing that will need to change is if you have a a sidepost mount distributor on the 95, if so you will need to swap distributors and that's it... You will have a crank sensor on the 95 but this can be safely ignored...
