Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 07-01-2004, 03:05 PM
jdrumstik's Avatar
jdrumstik jdrumstik is offline
88 Lude shifting?
I keep getting dogged, by every one on the streets. even a riced civic. MY lude is totattly stock an si, so I was woundering where should I be shifting and at what rpm should I launch? ive been shifting at about 7,200 rpm, (my tach rpm is 7,000 rpm redline)
what do you think?
Old 07-01-2004, 03:21 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: 88 Lude shifting?
How many miles is on your car... that could be the source of the problem. Old engines don't perform well. In any case, you should be shifting at a little over 6200rpm, because the 2.0L Si's engine does not make any power past that point.
And you may have met a Civic Si.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 07-01-2004, 10:04 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
I also have an 88 si. I shift close to 6500. Let me know if you need help finding aftermarket parts. They are hard to find for our 3rd gen preludes. Here is the work on my car http://www.cardomain.com/memberpage/528935
[IMG][/IMG]
Old 07-02-2004, 02:02 PM
car_boy_16 car_boy_16 is offline
No 3g ludes redline at 7k rpm. JDM b20a's redline at 6500rpm I believe, B20a5's redline at 6750rpm, b21a1's at 6500rpm.... And your shifting at 7200rpm?! Did you know at 7200rpm the ECU cuts fuel to the engine? That's a no-no, and no-one should rev these engines so high unless they are built. I hope your bearings aren't jacked.
Your probly losing to all these civics because you most likely need a rebuilt (mainly due to piston rings (95mm stroke & a Rod:Stroke of 1.49))
This means its not an engine that likes to be revved too high, it's not very good to over-rev this one or you might be greeted by your connecting rod at a bad time.
Old 07-02-2004, 11:27 PM
AcesHigh's Avatar
Prelude Guy
Redline is not always the point to shift.
Old 07-03-2004, 01:46 AM
Re: Re: 88 Lude shifting?
Totally agreeed....I hope I wasn't giving anyone that impression.
Old 07-07-2004, 05:37 PM
jdrumstik's Avatar
im sorry my mistake, the tach redline is at 6,800 but I shift right at 7,000, and it stops dead at 7,200. my mistake I miss typo.
also I have 160,000 miles on it, but I had valve work done at 110,000 miles if that means anything.
also I find when going up steep hills shifting at 6,000 rpm producs more toque and better acceleration.
so what do you think. I need a rebuild?
Old 07-11-2004, 12:19 AM
You will know if you have to rebuild when you do a leakdown test on the engine...
