Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-01-2004, 12:18 PM
bobby95 bobby95 is offline
95 gc miss while de-accelerating
Jeep idles fine accelerates fine, only problem is when I get up to speed and start to back off the gas a little it stumbles. This is especially prevalent when the cruise control is engaged and going downhill. Just had heads resurfaced, valves reseated. Still getting a Code 14 trouble code for MAP sensor even after changing out sensor. I feel like it is a sensor but I don't want to spend time and money changing out sensor after sensor till I get the right one. Anybody else had a problem like this?
Old 07-05-2004, 07:36 PM
Re: 95 gc miss while de-accelerating
I changed out the Throttle Position Sensor also with no luck. Checked for a leaking intake gasket by spraying starting fluid around intake while jeep is running. It never idled up or anything so I feel like the intake is fine. The service manager at the Jeep dealership said it could be a pressure transducer in the transmission (I trust that guy about as far as I can throw him). It stumbled once while idling yesterday and I got a O2 sensor code. Guess I'll try that next. Need to hear from you experts on this one, its driving me crazy. Thanks in advance.
Old 07-13-2004, 02:50 PM
Changed out the O2 sensor today-that's not it either.
Old 07-17-2004, 05:33 PM
Problem solved. Turns out the intake gasket was leaking after all. The distributor cap and rotor button wers shot as well. A big thanks to Dale for taking the time to give free advice. Much appreciated.
