Old 07-01-2004, 10:00 AM
MrBB's Avatar
MrBB MrBB is offline
Lightbulb Heads...
I was recently told that it is possible to install Windsor heads on a 289 or 302 engine using two gaskets in between the heads and intake manifold. Is this possible? I was told this will give significant power gains. I was thinking of attempting this because I have a 289 that I would like to put a 4 barrel carb and intake on for a little more power. Any comments appreciated!!
Old 07-01-2004, 10:38 AM
Wolf's Avatar
Wolf Wolf is offline
Send a message via AIM to Wolf
Re: Heads
Never use multiple head gaskets. That's just asking for leaks. You don't need to replace the heads in order to install a 4bbl, you just have to replace the intake manifold.
Old 07-01-2004, 11:03 AM
MrBB's Avatar
Re: Heads
I was planning on getting a new intake and carb so I thought that I would do the heads at the same time...
Old 07-01-2004, 12:47 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Heads
Windsor style heads will fit a 351w, 302w, and a 289 which is also a windsor block. The only difference is the intake width.
Old 07-01-2004, 12:57 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
he was saying, double up on the intake manifold gaskets, not the head gaskets. as far as this whole thing goes, i don't see why not. i'm not sure how much difference a pair of stock windsor heads will make. i know you need special washers to make it work due to the increased head bolt size.
hell, i have a pair of heads off my 351W that i'm building. they need to be baked and need valve jobs, but they'll work. pretty heavy tho, so it depends on whether or not you want 'em shipped from Michigan.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 07-01-2004, 01:02 PM
redhorseV6 redhorseV6 is offline
Send a message via AIM to redhorseV6
go for GT40 heads! they fit too, and hey, GT40 heads! how can you get cooler?
Old 07-01-2004, 06:25 PM
boosted331 boosted331 is offline
Re: Heads
You're right, how can you get any cooler. Heavy, overpriced iron heads that flow marginally better than E7's. Awesome.
Old 07-03-2004, 04:20 AM
speedfreak's Avatar
speedfreak speedfreak is offline
Send a message via AIM to speedfreak Send a message via MSN to speedfreak
Re: Heads
Which makes about as much sense as using doubled-up head gaskets.
351W heads can in fact be installed on a 289/302, but you'll have to mill them if they have large chambers or you wil lose alot of compression and you'll need either stepped head bolts or washers for the bolt holes. 351W heads have a 1/2" bolt hole while 221/260/289/302 has 7/16".
1968 Mustang notchback Roller 302, Edelbrocks, Hookers, side-exits, RRs, Crane 2031, Duraspark, forged slugs, X-Celerator, 650DP, Fidanza FW, RAM clutch, Toploader, Comp Plus, McLeod bell, 15x7s, 1 1/8 swaybar.
1972 Ford Pinto SVO 2.3 turbo, MegaSquirt, T5, 8", etc.
'95 Honda XR600-10.5:1, 628cc, ported head, & more.
Old 07-03-2004, 10:18 AM
rerun rerun is offline
ug...
for 351W heads to fit in 289/302 engines, all you need is new bolts, or you can machine the old heads if you have the cash. there is no change is gaskets, and you do not need to double anything. the power increase is major over the STOCK 289/302 heads - worst heads ford ever made on one of the best engines they ever made.
although, there will be a drop in compress by about .5:1, which really could just kill the preformance and make it slugish if your current compression is any lower than 9.5:1.
Old 07-05-2004, 12:56 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
With the amount of aftermarket head choices out there the 351W head swap isn't that common anymore. However, all that is required is a nifty set of head bolts that ARP makes, they have the thick 7/16 shaft but a 3/8 thread. You can also use spacers that make up the size difference and use the 3/8 bolts. You don't need to double any gaskets.
You can mill the heads to bring your compression up, but you also need to mill the intake accordingly if you do this. Flattop or domed pistons are a better way to increase compression, or use aftermarket heads with 58cc chambers.
The only reason a 351 intake is wider is because of the taller deck height of the 351 block, this moves the heads farther apart.
I hope this helps a little...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 07-05-2004, 07:12 PM
speedfreak's Avatar
Re: Heads
Eh, 302s take 7/16 bolts already and 351s need 1/2 inch.
Now that I think about it, hipo 289 or 302 heads would be better since they would have small chambers and about the same stock for stock and ported vs. ported flow. They will need bigger valves, though, so its either pay for milling and special head bolts for 351 heads or get new valves and seats for the 302s.
