Old 07-01-2004, 09:50 AM
MunkySpunk's Avatar
MunkySpunk MunkySpunk is offline
Door Panel
I know this has been addressed before, but for the life of me, I can't find the post on any of my searches.
Does anyone know how to remove a Del Sol door panel? I read a post a while ago with a definitive answer, but it seems to have vanished. I know there's a few screws and then just prying it off with clips, but I'm not sure which screw are the important ones.
Also, are there any things I should be aware of when removing them or putting them back on? Anything funny that I should be careful of or make sure not to pull too hard on, any re-alignment issues with handles or the like?
Thanks
- 1997 Del Sol Vtec - El Diablo Verde
- Team Sol International #1454
"It was a wonderful machine: Ten grand worth of gimmicks and high-priced Special Effects. The rear window leaped up with a touch, like frogs in a dynamite pond.... The dashboard was full of esoteric lights & dials & meters that I would never understand - but there was no doubt in my mind that I was into a superior machine."
- Hunter S. Thompson
Old 07-02-2004, 05:39 PM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: Door Panel
remove all screws. There's one behind the door handle, one behind the door pull/armrest thingie, and one in the front corner, right at the front edge of the door. To get the the last one, take a rachet with a 10mm attachment on it. Get a phillips head drill/screwdriver bit, and use that to get it out. A full size screwdriver won't fit in the gap between the pillar and the door. After that, I found that the easiest way to get it out is to remove the door handle from its hole, then get either a knife or a flathead screwdriver and pop the interior panel off along the edge. Then pull and it should come out pretty easily for you.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
