Old 07-01-2004, 07:51 AM
Snake_Man Snake_Man is offline
Need some help with my box
I just want to make sure if i build a box with a volume of 0.88 that my Image dynamics IDQ 10 D2 V2 sub will sound right in it. I tried using that winisd program but couldnt figure it out. Recomended space for that sub is 0.30-0.60 cu ft. If the box is bigger than the recomanded specs does that really mater? i know to small does. But 0.88 empty should be around the specs once the sub is in right?
2003 Ford Ranger Edge Supercab Black
Bedliner bugshield Chrome bars class3 tow hitch
Pioneer 4600mp, Pioneer 6x8 240watt 4way in all 4 doors
Rockford Fosgate 501x 1500watt 65x4
Image Dynamics IDQ10 V2D2 sub
Walmart crap box (needs replacing SOON)
Old 07-01-2004, 05:17 PM
DJ Brady DJ Brady is offline
Send a message via AIM to DJ Brady Send a message via Yahoo to DJ Brady
Re: Need some help with my box
in my experience, putting a subwoofer in a box larger than it's intended destination will provide a steeper response curve in the low frequencies (40 - 70Hz), but offer VERY muddy punch bass (100 - 200Hz), it loses it's ability to provide a nice flat response. I accidentally built a box a little too large for my Kicker 12" but it's a very nice box so I'm going to experiment with spray adhesive and accoustic panels on the inside of the box to reduce the internal volume. I know materials like Fiberfill and Fiberglass Insulation can fool a speaker in a smaller box by reducing rebound waves, but I'm contemplating using a dense 5/8" cardboard type material designed for recording studios.. I think it will do a good job of reducing internal volume.
Old 07-01-2004, 11:54 PM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
You can always add just plain old MDF or particle board to the inside of it. Anything inside the enclosure is reducing the internal volume. When I want to experiment with enclosure size I build one that is much larger than specs and reduce it from there with calculated pieces of wood. I have even used chucks of 2X4 to do so.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
Old 07-02-2004, 12:30 AM
well its built but i think i made it to big the thing is a beast lol im gonna test it when my sub gets here if indeed its to big im gonna cut it down an inch or 2 that way it will fit better behind my seal also
Old 07-02-2004, 02:19 AM
good luck man. keep us posted.
