Old 07-01-2004, 02:13 AM
acgr76 acgr76 is offline
Send a message via MSN to acgr76
Transmission ID
I have a 1992 silverado 4x4 manual transmision, 5.7l V8 TBI, convencional cab.where can i see what transmision it is} Munice 117mm, Getrag 85mm, Nvg 4500, Nvg 5lm60, Nvg 3500 and what type and brand of oil is best?...
Old 07-04-2004, 09:39 AM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
Re: Transmission ID
on auto trans use royal purple Max ATF,on ur manual trans use Synchromax, and for ur diff. use Max-Gear 75w90
u can get anything of royal purple from any performance shop and or napa auto parts
Old 07-04-2004, 06:47 PM
HDChvyTrk HDChvyTrk is offline
Re: Transmission ID
If you e-mail me your VIN I can tell you what trans your truck has. Most newer GM Manuals use ATF. Others use Syncromesh. It would be best to be sure. You can also call your local dealer and give them your VIN.
Old 07-06-2004, 04:00 AM
thanks faze2183, is synchromax the same as syncromesh?
vin 1GCEK14K9NZ******, i think the rpo says its a 5 speed, new process, 109mm, 6.34, thanks for the help
Old 07-06-2004, 05:58 PM
Re: Transmission ID
well i just knw that the synchromax can last hella longer then any other fluid u throw in there, though like on my auto i change the fluid every 12k just to be on the safe side and etc
Old 07-06-2004, 06:01 PM
Re: Transmission ID
but to answer ur question i think it is but im not sure its made for manual trannys so im guessin yes
Old 07-07-2004, 04:11 AM
thanks i'll try the synchromax
