Old 07-01-2004, 01:32 AM
streetracer1 streetracer1 is offline
grommet in floor
ok well im getting a new flowlighting 7 color ub kit and i have to run each wire from the tubes taht are mounted under the car on each side, i ahve to run the wire into the cabin where the ecu is .. does anyone know if there is a grommet in the floor of the grand prix.. i have a 99 gt... like not a grommet in firewall but in the floor area.. cause i know some cars do.. .thanks
ryan
Old 07-01-2004, 06:40 AM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: grommet in floor
Im pretty sure there is a gromet in the rear under the back seat.
Old 07-01-2004, 11:30 AM
ok thanks i will check that out today thanks ripn .. your always a good help
Old 07-02-2004, 12:55 AM
thanks i actually found some... woohoo much easier to install my ub kit now. thanks ripn
Old 07-02-2004, 04:20 PM
bcreverend's Avatar
bcreverend bcreverend is offline
easy gromit
there is a huge gromit in the front passenter floorboard that i ran the cabels from my led's through, all you have to do is peal the carpet back
silver 99 grand prix gtp with Intense standard pcm, 3.4 intense modular pulley, oversized supercharger idler pulley, zzp underdrive water pulley, zzp overdrive alternator pulley, tps enhancer, open cone filter, thrasher shift kit, strut tower bar, eibach springs, autolite spark plugs, 180 degree t-stat, throttle body spacer, flowmaster catback w/U-bend delete, Rear O2 simulator, silvania headlights, xenon foglights, 40 cp reverse lights, and a custom 600 watt audio with cd changer.
Old 07-03-2004, 12:19 AM
yes i know that... im using the side grommets for my side tubes cause all my main ECU and controllers are inside the car instead of under the hood.
