Old 07-01-2004, 12:25 AM
StickyMits StickyMits is offline
HELP!...Oil Pump?
today i was driving to work when i looked down at my oil pressure guage(right next to the stock boost guage) and it was completely buried in "L". What could have happened to it...everything seemed fine performance wise. My brother said it might be my oil pump...but i dont know what it could be, then again I still am learning. If anyone can help me with my problem I would greatly appreciate it.
Old 07-01-2004, 12:29 AM
oh yea and i dont see any oil leaking from anywhere.
Old 07-01-2004, 12:47 AM
joemathews's Avatar
joemathews joemathews is offline
Re: HELP!...Oil Pump?
Sounds like that could be the problem...or your oil pressure sending unit that services the gauge. Is your car overheating or getting hotter than usual because of added friction? If not, it could be a gauge problem...
1996 Eagle Talon
Old 07-01-2004, 01:57 AM
98GSX's Avatar
98GSX 98GSX is offline
Send a message via AIM to 98GSX
check out the sending unit wire ... its a pos!!! also check the oil filter.. if its loose.. you have to take that off and tighten the stud taht holds it.. that happened to me and i roasted my bearings... and also at the same time the water pump went out... and a clogged radiator.... WOW PROBLEMS! well now i took the motor out boring it .20 over with JE pistons, EAGLE rods, ARP studs...
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE
^^^ hehehe
2000 Ford F-250 boostin' 30 psi
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
1991 Geo Storm boostin' 10 psi
1998 Eclipse GSX boostin' 16 psi
1991 Oldsmobile Cutlas Calais
Old 07-01-2004, 04:55 AM
kjewer1 kjewer1 is offline
AF - Advisor
That wire does fall off or break over time. There are two. The one towards the front of the car is for the idiot light. You can just crimp on a ring terminal if that gets hosed. The one to the rear of the car is for the guage itself, and there is a shyte connector that slides sideways over the pin on the sender. You can get creative with cutting up a female spade lug, but it still sucks. Try to keep the stocker there as long as possible, which means dont drag it under the car for 2 weeks before you decide to reattch it
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
