Old 06-30-2004, 07:15 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
Question of all things to be broken....
hey guys - long time no smell.
89 lx convertible.
passenger quarter window is down and won't go up, so i figured it was the motor. I dug in and pulled it out and before i disconnected it i reconnected the battery and tried to see the gears on the motor spin. to my amazement the motor would drive down but not up, regardless of the switch i used.
my current theory is that somewhere along the lines there is a break in the connection that tells the motor to go up when the up button is pressed. how should i attack this problem?
you guys are great.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 07-01-2004, 01:54 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: of all things to be broken....
Try the motor from the other door, just to verify that it is indeed the motor. I had a cougar with the same problem and it was in the motor itself, not the wiring.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-01-2004, 03:40 AM
the quarter window on the other side (right) works fine, and just to double check i connected another motor to the left harness and it behaved the same way. bigdan=sad
free hypsi87!!
Dan's White Horse
