Old 06-30-2004, 06:21 PM
sLADe781 sLADe781 is offline
Alarm system installation
I'm going to be getting an alarm system this Friday and was wondering if anyone has installed a system into a 3KGT before? Are we going to have to take the whole door apart? Sure hope not.... Any instructions/tips/advice would be much appreciated. Thanks folks.
Old 06-30-2004, 08:26 PM
Igovert500's Avatar
blue + red light magnet
Re: Alarm system installation
Here is something I just came across on programming new keyless entry remotes for an aftermarket alarm:
Q: How do I program the remote for keyless entry?
A: Programming the keyless entry receiver will be required when you purcahse a replacement "FOB" or keyless entry remote unit. The keyless entry receiver is located behind the rear interior panel near the drivers seatbelt (drivers side). Here are the steps for programming your remote for keyless entry:
Remove the rear hatchback cover
Remove the rear seat:
Pull the two handles near the center of each seat section on the bottom portion of the seat
Lift the seat bottom upwards and set aside
Remove the two 12mm bolts at the base of the rear seatback on the drivers side
Remove the driver's side rear panel:
Remove the rearmost screw on the plastic strip that sits over the rocker panel
Remove the screw on the cover of the rear seatbelt retractor then remove the cover
Remove the screws holding the seatbelt harness from the frame. This can be tricky since there is little room to work with. Use a stubby screwdriver
The seatbelt itself does not need to be removed. You can just remove the harness and leave the seatbelt threaded thru the panel
Remove the screws closest to the rear of the car that are located on the plastic header and footer around the drivers doorframe. These typically overlap the rear panel by a small amount and may need to be loosened to move the rear panel
Behind the rear panel you should see a box in front of the rear speaker - this is the receiver unit
Remove the receiver from the car body
Find the switch labeled SET 1 - FIX - SET 2 and move the switch to either SET position. (the two SET positions are in case you have two transmitters with different codes)
Press any button on the remote transmitter
Move the switch back to the FIX position
Test the new remote transmitter
Reconnect everything making sure that the antenna connector is tightly connected to the receiver
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-01-2004, 12:50 AM
gen_meridus gen_meridus is offline
Send a message via MSN to gen_meridus
Just out of curiousity, me being dumb...., did all 3000GT's come stock with and alarm system? Cuz I didn't get a keypad with mine if they did.
92 3000GT SL
Trying to find people to help with a Base/SL to Twin turbo conversion. If you wanna help or have any helpful ideas besides giving up, give me a shout. I'm going to Denver Automotive and Diesel College for high performance, maybe it'll help....or not.
Old 07-01-2004, 02:28 AM
Igovert500, is programing a keyless entry the same thing as installing an alarm system? Because I was thinking that I'd have to like hook some stuff up that connected directly to the "lines" for the car locks and so forth. But I've never done it before so I don't really know....
Old 07-01-2004, 09:52 AM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
When I got my ride insured yesterday the chick asked me if the alarm system came with a locaitor (like lo-jack or some other brand name), I have a viper alarm system so does anyone know if it does and how I would prove I have it without the stupid paperwork the insurane people want?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 07-01-2004, 11:29 AM
Igovert500's Avatar
Thourun, I have a viper and I don't think it does. Then again, I wasn't the one who had it installed, so I really don't know.
Slade, no they aren't the same, if you are installing an alarm, there will be more work, like running wires and other stuff I don't know about. What I posted before was just something I stumbled across. It is probably just the last step in installing an alarm, because you will probably want the remote on your alarm to do more than just disarm the alarm, you will want it to unlock the doors as well. So that is where my first post will come in handy...i think.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-02-2004, 01:22 AM
Well, I'm planning to get the Viper 791XV shown here:
http://www.viper.com/security/viper/viper_responder.asp
Well, does anyone know how to hook up the whole alarm system?
Old 07-02-2004, 06:51 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: Alarm system installation
yeah, goto www.directed.com and look up guides then to install. That will get the info on the alarm. Then goto www.bulldogsecurity.com to get your car's info.
Old 07-02-2004, 02:23 PM
Umm.....I don't get it.... The installation guides on www.directed.com were only for speaker stuff. And the bulldog place doesn't have the Viper 791XV series (unless if I can't find it). Help!?!
Old 07-02-2004, 07:34 PM
Sorry about that. They must be updating the system or something. The install guides for the security and such was on there a few weeks ago. As for the Bulldog site, that was for you to look up your car's wiring info.
Old 07-02-2004, 09:27 PM
Wiring info? What do you mean?
Old 07-04-2004, 01:49 PM
The wires in your car needed to be hooked up to what ever aftermarket item you want to install.
