Old 06-30-2004, 05:49 PM
sniper4x4 sniper4x4 is offline
Send a message via Yahoo to sniper4x4
Question Weird brake light problem, ANY CHEVY TECHS AROUND PLEASE HELP
Ok a while back I swapped my OEM tail lights for a set of tinted APC's however they required red bulbs I tried a set of 3157 red coated ones but they only lasted a month due to the heat turning red into a light pink. No good so I bought 4 of the APC red LED 3157 bulbs (they don't have 3057 ones) & they seemed to work fine but just not very bright. After a few months one of the APC led's bulbs failed so I ordered a set from Jam Strait which are made special for the chevy (GMC same stuff) & I also ordered their variable load relay which took care of the fast blinker issue (which was caused by using the LED bulbs). Now I'm tired of them not being very bright & am ready to return it to stock & reinstall the OEM relay & remove the led bulbs & reinstall the original 3057 bulbs everything works fine except NO Brake lights ?
I tested with a volt meter & I have full power there at the tail light circuit all the way thru the circuit board up to the bulb contacts once I connect the bulbs nothing ?? for now I'm using the LED bulbs cause they work but I'm at a loss why the originals bulbs wont work ? I've tested each bulb & they all work both filaments, I've tested continuity across this tail light circuit board & have continuity all the way thru & I have 12 at each of the wires park lamp circuit, brake(includes blinker), reverse & ground. Any suggestions ?
thanks in advance
Toys:
11' Camaro RS
99' GMC Suburban 10" lift
00' Mustang GT Conv.
07' High Jumper Sandrail (For Sale)
My favorite Toy 73 Kona 463 Olds
Old 06-30-2004, 05:51 PM
Re: Weird brake light problem
If it matters any I forgot to mention its a "old body style" 99 Suburban
Toys:
11' Camaro RS
Old 07-09-2004, 01:02 AM
Does anyone have any suggestions ?
Toys:
11' Camaro RS
