Old 06-30-2004, 04:29 PM
landtoy80's Avatar
landtoy80 landtoy80 is offline
Power window motor removal
I need to remove the motor and fix/repair it.
The service manual says to drill a hole in the regulator and backing plate and put screw in it.
I don't know where to drill a hold? Do I drill into the door and into the regulator or is there a hole in the door to drill into the regulator?
kurt
87 3/4 ton Turdvalanche "Turd" 4x4 TBI 350 (was a Sub)
94 Land Cruiser
Old 07-02-2004, 02:46 PM
cheesehead69 cheesehead69 is offline
Re: Power window motor removal
After you get access you will see a rivet at one of the mount positions,,about the size of a dime,Drill it out and install a hex head screw,if I remember right it is towards the rear of the door/regulator
Old 07-03-2004, 12:08 AM
landtoy80's Avatar
I took the whole regulator and motor out. It slid right out. I then drilled a hold and put a screw in and removed the motor.
The motor is dead. I need to get a used one to replace it .
kurt
94 Land Cruiser
