Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 06-30-2004, 05:14 PM
zx2goon zx2goon is offline
Replaced air filter - now service engine light on
Hi all.
Recently replaced air filter in 1998 zx-2 - The first time I started her up afterword, she ran really, really rough - couldn't drive her. Shut her down, checked for messed up hoses, connections, nothing. Tried starting her again, and it got better - ran fairly well - Thought maybe the computer needed to get used to the clean filter (the one I replaced was stuffed full of dirt). After a couple more starts, she ran fine - has been running fine ever since, but the service engine soon light has been on since I replaced the filter. HELP!
Old 07-01-2004, 02:11 PM
proceniram proceniram is offline
Send a message via Yahoo to proceniram
Re: Replaced air filter - now service engine light on
Maybe one of your sensors went bad and there for tripped your service engine light.
Old 07-02-2004, 11:24 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
maybe you got stuff on your MAF sensor, thats a comon problem, if you reset the computer (disconnected battery) it will run ruff for aobut 1 min or 2
Old 08-11-2004, 09:38 PM
eyesonly54 eyesonly54 is offline
I've been having a similar problem and had a diagnostic ran. It showed that my throttle position sensor was bad and needed to be replaced.
Now, I just have to figure out how to replace it. LOL.
Old 08-12-2004, 04:47 PM
Hodo Hodo is offline
What airfilter did you put on. If it is a incorect filter, or a oiled air filter, WILL ruin the mass air flow sensor (MAF). Trust me Fords are pretty bad about the MAF, it can be real twitchy over what kind of air filter you use.
Old 08-12-2004, 11:33 PM
Banned
ummm if oiled correctly(most come pre-oiled) a oiled filter WILL NOT ruin the MAF, and its not twitchy at all as long as you know how to not over oil
Old 08-16-2004, 07:18 PM
Zx2srdotnet, thats the key if you dont over oil them. Some can get over oiled prior to install, some could just have had a possible film or a junk on the inside of the filter that may blow off into the MAF. It could also be that something else ended up in the pipe while the filter was off. And yes the MAF on that car is that twichy, had some bad experiance with some oiled filters.
