Go Back   Automotive Forums Car Chat > Geo > General Discussion
Old 06-30-2004, 02:47 PM
BRUCEDU BRUCEDU is offline
1992 tracker
I have a 92 tracker that will not start unless I squirt gas into the throttle body, when I do that it will start and run fine, also there is alot of fast clicking coming from under the dash, drivers side by fuse box. any ideas?
Old 08-13-2004, 05:26 AM
jellison jellison is offline
Re: 1992 tracker
My 92 Tracker had the exact same problem.The very expensive repair included an ignition and ecm module! I believe the fast clicking was the fuel pump relay. What did you find with your tracker ?
Old 08-29-2004, 08:25 PM
BMXMom BMXMom is offline
Re: Re: 1992 tracker
How expensive???? My son is looking to buy a 91 Tracker 4X4 that appears in great shape, 72000 original miles, but the owner (a friend of ours) has to spray a little ether before it will start. This trick doesn't help in cold weather. I drove it earlier and it runs great. The price is $500.
Old 08-30-2004, 07:37 AM
Re: Re: Re: 1992 tracker
The cost of repair in canadian dollars was 1360.00 however this included an ignition switch $250 and an ecm module $500 rebuilt as well as a lot of labour costs diagnosing the problem. I believe the problem was the ecm module which I have seen on the net (autoecms) for $250 us. If you know a GOOD mechanic they should be able to confirm your problem
Old 09-06-2004, 01:10 AM
We haven't bought it yet, but it is at our mechanics right now. Hopefully it's not too expensive. Thanks for your help!
Old 10-16-2004, 08:17 PM
crawfora crawfora is offline
I've seen a lot of these ecm's on eBay for a little over $100.
