Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-30-2004, 02:25 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
LS crank in a B17 block
Can I use a LS crank in my B17 block with my B16 rods ?
this would make a Stroked b17 .
originaly i was planning on running a Built b17 but the B17 crank is too bad and is not worth fixing.
I pretty much gave up on finding a B17 crank and I know I can get a B18b crank pretty easy.
the B18 crank is the same as the B20 and the B16 Rods are 0.004" shorter than the b18/b20 ones. ... I just don't know if the B17 block will take this kind of stroke... any one have any imput on this ?
Kun
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 06-30-2004, 03:25 PM
boosted331 boosted331 is offline
B16 uses a shorter deck height than B18's, so you'll need to run either a stock length rod and a piston with the pin pushed higher up, possibly even into the ring package, or run a shorter rod and a stock LS comp height piston. Both of these setups are far from optimal, I would recommend just getting an LS motor and swapping it in.
Old 06-30-2004, 10:42 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
B17 is just a stroked B16a so I would think that adding the B18 crank would in a sense stroke it too much? I dunno I'm not sure of the technical problems you may run into here. I agree with boosted 331 just get an Ls motor, or actually why not just get a B16 crank wouldn't that work alot better than the B18 crank?
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 06-30-2004, 10:57 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: LS crank in a B17 block
Why not just try to find a B18C1 bottom end and use that? Or use a LS bottom end like said above.
Old 07-01-2004, 02:03 AM
RPMtuner RPMtuner is offline
why not get a ls bottom end and put the vtec head on it
Old 07-01-2004, 05:54 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
there will be lot's of unwanted vibration in the upper rpm's, wont be good for the motor after a pd of time.
2002 Acura TL Type S
1991 Honda Crx Si
