Old 06-30-2004, 01:44 PM
MStout's Avatar
MStout MStout is offline
Damping
I have been wondering this whole time what makes Dynamat more expensive than Secondskin, other than the fancy brand name. I am planning on buying the 20 sq/ft pack of Second Skin Damplifier and was wondering if its better than most other damping products. You get way more for much cheaper compared to alot of other companies...and if it does the job just as well as them, that would be awesome. 20 sq/ft should easily cover the trunk lid, sides, under the box and maybe even parts of my front doors shouldnt it?...In my Neon obviously...Any input would help.
Old 06-30-2004, 04:56 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the more expensive brand names tend to stick better to the applied surface and usually don't have as bad of a tar smell
Old 06-30-2004, 05:01 PM
DJ Brady DJ Brady is offline
Send a message via AIM to DJ Brady Send a message via Yahoo to DJ Brady
Re: Damping
Worst case scenario, buy a can of Super 77 or Super 90 from wally world, that stuff will adhere anything.
Old 07-01-2004, 09:28 PM
r8erz4life r8erz4life is offline
where do you get this second skin stuff?
Old 07-02-2004, 12:10 AM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
Re: Damping
PaulD is on the money. Another thing about the more expensive stuff is that it is more plyable. It is alot easier to stretch and conform some of the "higher end" sound dampners. That really is just for ease of installation. Here are a few good pointers. Make sure the metal is very clean. I use laquer thinner or denatured alchol before application. Also..this part sucks but really helps. Try to do it on a very hot day. Lay the pieces of material adhesive side up in your driveway for as long as you can. The heat will make the material stretchy and the adhsive is activated by heat. A good roller always helps and so does a heat gun. Be careful not to burn yourself and be careful when putting it down around places like the seat bolts and door panel clips. Remember you have to put the car back together afterwards.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
Old 07-03-2004, 10:41 PM
Audio Guy
Re: Re: Damping
awww ... you take all the fun out of it
