Old 06-30-2004, 09:39 AM
RSLaser RSLaser is offline
Do it ur-self cold air intake
ive done a custom cold air intake on a 79 mustang, but how can i do one for my laser? The main problem i am having is tryin to figur where to put the sensor on inside of the air filter. hope thats not too confusing.
1991 Plymouth Laser RS
Only sat for a few years....
Old 06-30-2004, 11:09 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Do it ur-self cold air intake
I am guessing it is the MAS sensor. You can make it in two pieces and put one on each side and then use hose clamps.
If it is a plug type sensor.. i guess you could drill a hole and put in a fitting (forgot there exact name they are gray) and use abs cement to hold it in place in the hole. Then you could screw the sensor right in.
For Sale 98 Eclipse GS, 5 spd
Old 06-30-2004, 12:26 PM
yes its the MAS airflow sensor. but its haped kinda funny and it didnt seem like it would fit it the tubing.
Old 06-30-2004, 04:33 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
look up the POSr home depot intake.
Old 07-01-2004, 04:16 AM
kjewer1 kjewer1 is offline
AF - Advisor
The "www" button below my posts will take you to the pos website... The process is similar for a 1g, but the MAS needs a 3" coupler, not 4. Its easy to figure out once you get started.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
