| Off-Topic Talk about anything other than cars. |
Eprom???
ok ive been reading on these threads and fpund out that my 95 gs-t should have a EPROM ecu.... what is that? whats is stand for ... im very curious because ive heard that they can be good?
thanks n advance |
Re: Eprom???
An eprom ECU contains a removable chip (once it is socketed) on the circuit board. This allows for the interface with DSMLink (www.dsmlink.com) through the OBD-II port. DSMLink is considered to be the ultimate in tuning and logging. It actually changes values for air, fuel, etc. within the ECU itself as opposed to intercepting the ECU signal and "lying to the ECU" (SAFC-II). It is also the only logging tool to log knock. Most all 95's have an Eprom ECU. You can tell by removing the ECU and looking at the sticker on the top. An eprom ECU will have an "E" in the lower right corner of the sticker.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Re: Re: Eprom???
so if i have one of these im lucky ??
Re: Eprom???
yup, it will only benifit you tho if you are getting dsm link
THE OFFICIAL AF PIMP! - love EclipseRST[Banned] ![]() 1997 Gs-t Eclipse ![]() 6 bolt + other toys Currently 295whp |
Re: Eprom???
The E sticker is not fool proof. Open it up to be sure, it takes 2 minutes more time. www.tmo.com has instructions and pictures so you can locate the eactual EPROM chip on the baord.
Not only is DSMlink an option, but TMO and Jeff O chips, etc.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
