Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-30-2004, 01:25 AM
MMMauto MMMauto is offline
Question no start
1993 Nissan 240sx
2.4 liter 5 speed
Timing problems
I recently did a cam swap, swapped a set from a 92 240 to see what happens.
Turned out great actually, then I decided to try a mod that uses both exhaust cams for the engine. This didnt turn out so good and now my car cranks over but it doesnt start. I know everything on the engine is lined up correctly, because when I crank it over manually, all the timing marks/distributor/camshafts act the way they need to. Also, when I use a timing light, I cant find the timing marks on the crank pulley
Old 06-30-2004, 07:16 AM
SHO411's Avatar
SHO411 SHO411 is offline
Re: no start
Wait a minute, are you saying you used the exhaust cams on the intake side too?? what do you mean by "use both exhaust cams for the engine"??
And if you did, what possesed you to do that anyway????
Ain't this the pretiest motor or what?
Fines are the fee you pay for the privilege of driving as fast as you want
Old 06-30-2004, 10:44 PM
eclipse2quick21 eclipse2quick21 is offline
id say just do what you did the first time, since it worked right.
Old 07-01-2004, 12:57 AM
zeroneonzn zeroneonzn is offline
Banned
Send a message via AIM to zeroneonzn
Re: no start
put the things bak to stock and take it to a mechanic
Old 07-01-2004, 07:46 PM
Chuki_breath Chuki_breath is offline
Re: no start
yea i heard about that....putting 2 exhaust cams in, like ur supposed to gain a few hps or something....but just put it back to the way you had it when it was working.
i mean if you want to play with cams that bad just go and buy some.
