Old 06-29-2004, 08:52 PM
kidgonzo79 kidgonzo79 is offline
Please help
I was just given a 93 escort so i could keep my WRX in the garage so i don't put too many more miles on it. I am trying to get it inspected and on the road. I went to replace the front rotors and the drivers side came off no problem. The passenger side on the other hand still hasn't come off. I've tried just about everything. Also, there is supposed to be a bolt in the rotor, also not there. Also, the brake lights don't work and the fuse isn't blown. And the heater fan stays on no matter what the setting on the controls. Any help would be greatly appreciated. Thanks
Old 06-29-2004, 10:27 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Re: Please help
the bolt on the rotors is optinoal, not always there. brake lights you can just say fuck it and buy new bulbs for like 1.29 and see if there blown, and ive had problems with my blower not coming on, but I just cleaned the ground wire underneath the glovebox, it was rusty. so there are a few thoughts and by the way....you suck, I want your other car.
Old 06-30-2004, 08:45 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: Please help
GIVEN a scort so you "don't put too many more miles" on your WRX?!! Damn you, give me your WRX if you dont wanna put too many more miles on it. You can have my '99 Escort, runs fine...
Old 06-30-2004, 02:52 PM
Re: Please help
The taillights come on, but the brake lights don't. Can one go out and not the other if its the same bulb? I just looked at the blower motor and it looks like it has been jerry-rigged.
Old 06-30-2004, 02:56 PM
Jet-Lee's Avatar
Banned
Re: Please help
yes, the bulb has 2 filaments, one can be blown. get a wiring diagram and wire the blower motor correctly. Even if that doesn't solve the problem, it could fix potential future problems.
I'll still trade for your WRX
Old 07-01-2004, 08:26 PM
Re: Please help
also, is there any way to get the stud on without taking the hub off??
Old 07-02-2004, 07:34 PM
tofast4u2catch tofast4u2catch is offline
Re: Please help
Nope. Not safely anyway.
Old 07-02-2004, 09:08 PM
Re: Please help
man, not the answer i wanted. Thanks
Old 07-02-2004, 11:52 PM
Re: Please help
No prob. It's really not that difficult. Just a little time consuming. Good luck.
Old 07-06-2004, 01:25 AM
Re: Please help
Do i just undo the nut in the middle of the hub? I have a Haynes manual, but it doesn't really tell me much.
Old 07-10-2004, 02:44 AM
Re: Please help
Ok, how did you get the old stud out? I've put many of these on with no problem but not all cars are equal. See if there is a "notch" on the spindle. It will be distinct if so. If it does then CAREFULLY knock the old stud out and replace it with the new one. Using a C-clamp or equivalant tool, press the back of the stud to the spindle as far as possible. Next, use a ratchet/socket and try to pull it the rest of the way in. Don't attempt to "torque it" because doing so will result in a damaged spindle and a stretched stud. Good luck.
