Foglights....
Alrighty... I just got my new lights for my foglights. Everything was all good and well until I took off the cover of the foglights and tried to unscrew the 2 screws. THEY WILL NOT COME OFF....
Just a lil' frustrated.... I try to turn them but it doesn't work... I've already partially stripped one of them. Not too bad though. I just can't think of a way to get them off... Please help. |
I'm not sure if it'll help a lot but dumping WD-40 on anything thats stuck is a step I usually take.
Resistance Is Futile (If < 1ohm) |
I tried getting my fog's off so I could replace the bulbs but could not find any fasteners where are they? And are they screws or bolts?
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Thanks Yogs... I did that just before checking the thread. Hopefully it'll work after I try again after I eat ^_^
And for my 95' SL getting to the fog bulbs is actually pretty easy. All you have to do is pop off the plastic cover (there is a small metal clip on the side closest to the fender) Then there are two screws... Unscrew those, and you should be able to get to the bulb. Just hope they aren't rusted :-D |
Re: Foglights....
what about replacing 1st gen foglight bulbs? i know its a stupid question but is there a link or something. i think im embarrassed..
Thanks 3kgtnoob, I have a 95 SL also so it should work just fine
Yeah, np.
And sorry Kev, I don't know what the first gen are like. |
Re: Foglights....
yeah, i would like to replace my first gen fog lights as well, but what would fit in that socket? and look good? you know what's weird, the fog lights are projection bulbs and the headlights are old fasion..
Re: Re: Foglights....
i have a first gen and theres jus 2 clips and a couple screws and it'll come right out..then i jus got a bulb for it at pep boys and i spliced em together |
I managed to get one of the covers off (I think I broke it in the process not to bad though) and ended up stripping one of the screws on that side, I guess i'll try the WD-40
. How am I supposed to get off te clip thingy on teh other side it seems to be wedged between teh fender and the plastic cover, is there some trick to it?
Ya, I got the same problem, even tried cutting the screw off...but no luck, only got one side off, other side just stripped...drilling/cutting/bashing/ripping off foglight didnt do anything...pretty sure torching the screw will work though, but nothings gettin done for a while.
I had to bend one back and forth to get the screw to break off, now only one screw is holding on each fog light lol.
