Old 06-29-2004, 05:09 PM
david g david g is offline
ABS pump runs after motor turned off
I have a 2001 Chevy Tahoe that appears to have an ABS brake system problem. With the engine off a pump or motor continues to run near the rear axle of the truck. The ABS warning lite came on. Concerned about running the battery down I removed the fuse to the ABS system. The brakes continue to work fine with the fuse out. Of course, the dealer wants to replace the whole unit ($1200.00). Any suggestions?
David G.
Old 07-03-2004, 10:52 PM
happyguyy2k happyguyy2k is offline
Wink
Go on ebay and type in EBCM. Its a bad electronic brake control module.
Easy fix and wont cost but 125.00 plus your time.
Old 07-17-2004, 07:20 PM
fxdl fxdl is offline
antilock brake problems
These guys can save you alot of trouble and money
www.circuitsolutions.info
www.modulemaster.com
They will take you through it step by step. They saved me $1,200.00 under a dealer quote.
If your pump runs after you kill it, pull the fuse. You will still have brakes, just not the anti-lock
Old 07-18-2004, 05:27 PM
Re: antilock brake problems
Thanx for your help, I will give them a call. Sounds exactly what I have and what I'm looking for in repair needs.
