Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-29-2004, 05:02 PM
hovz hovz is offline
maxima questions
1995 maxima se w/ manual.
when i press the gas pedal theres a slight delay before it starts revving. its less then a second. is this normal?
sometimes when i press the clutch in and shift into reverse it doesnt go. i have to release the clutch and press it in again. this only happens with reverse and its pretty rare. cause?
shifitng is kind of sticky. for example when i shift into a gear its a little rough, but if i shift into nuetral and bakc into the gear its completely smooth. only the first shift is rough. however if i shift into a different gear then back into first its rough again for that first time.
sometimes when i start the car up, it makes a weird noise when turnin ghte key in the ignition. similar noise to turning the key when the car is already started.
check engine light is not on.
thoughts?
Old 06-29-2004, 09:11 PM
SledgehammerVette's Avatar
SledgehammerVette SledgehammerVette is offline
Send a message via AIM to SledgehammerVette Send a message via Yahoo to SledgehammerVette
Not sure about most of those problems, I don't own a 5spd sadly .
But the stickiness maybe due that you need some new transmission fluid. Redline has some great stuff!!! I have heard people praise it.
4DRSpeed.com Is Here!
Old 06-29-2004, 10:06 PM
Re: maxima questions
people plz help me!!!!
Old 07-07-2004, 03:28 PM
dustrman03
Guest
Posts: n/a
tranny fluid. if that doesn't work, get it checked out.
