Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-29-2004, 03:52 PM
keniq81 keniq81 is offline
Send a message via AIM to keniq81 Send a message via MSN to keniq81
Question Help What's with low profiles! Help NEEDED
Hi there! I am clue less with my new car that i just bought. A 01 Nissan Altima, that the old owner was working on adding things on and one thing is that they put 20" wheels and low profile. I am not sure if i like them low, what happens if i hit a nail? How do they handle in the snow?
I want to go from 20" wheels to 18" or 17", do i have to lower or raise it? What's the deal?
Kisses Kendle
Old 06-30-2004, 04:14 AM
Wolf's Avatar
Wolf Wolf is offline
Send a message via AIM to Wolf
Re: Help What's with low profiles! Help NEEDED
You shouldn't have to raise or lower it. The overall diameter of the tire will remain the same; the wheel diameter will decrease, and the tire sidewall height will increase. I'd say try to find someone with an Altima with the wheels you want and see if they want to trade- there are plenty of idiots out there who don't care if their car rides like shit, as long as it's got 'dubz'.
Old 06-30-2004, 09:36 AM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
20s on an Altima? Wow, that's way too low of a profile. Double check the tire and make sure it is at least an 89 load rating (after the size on the sidewall). You likely are running on overloaded tires if the load rating is lower than that. I don't know of a 20 with enough load capacity that will fit without rubbing. This car should have 205/50-17 or maximum of a
215/40-18 tire size.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Old 07-01-2004, 12:26 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
also, I wouldn't even attempt to drive with those in the snow, most 20" car tires aren't M+S rated.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 07-01-2004, 12:48 AM
SR240Z's Avatar
SR240Z SR240Z is offline
Send a message via AIM to SR240Z
wow 20s on any car ive seen besides the new 745i are huge
www.sr240z.com
www.VildiniMotorsport.com
1972 Datsun 240Z SR20DET
Old 07-04-2004, 12:03 PM
92'SiHatchBack 92'SiHatchBack is offline
Send a message via MSN to 92'SiHatchBack
thats big and you shouldnt have chrome in the snow any ways i always heard that it could crack or something like that.
I get asked why i drive a honda and i say...... Cause its faster than yours
Old 07-06-2004, 11:42 AM
The chrome finish will not hold up very well in colder temps. The plating process uses three different metals and each will shrink and expand at a different rate. In time, the layers will sheer apart and that's when they start to peel.
Grant
fax# 574-236-7707
