Old 06-29-2004, 03:41 PM
yakk's Avatar
yakk yakk is offline
Running Power to Truck Bed
I've got a Leer cap installed, and I don't like the way they installed the power to the cap dome light running off the tail lamp, which requires me to turn on the lights before I can turn on the dome.
I was thinking of running a line from the dome light to a constant power source to avoid this problem.
Any suggestions on the best source and routing to use?
thanks, Jack
Old 06-30-2004, 08:55 AM
simple_country_guy's Avatar
simple_country_guy simple_country_guy is offline
Send a message via Yahoo to simple_country_guy
Re: Running Power to Truck Bed
First question is... do you have a trailer brake. If you do then there will be power at the back of the plug. If not then you will have to run a constant 12v source from the battery( or the battery junction) along the factory wiring harness. It runs the length of the truck frame. JUST MAKE SURE THAT YOU FUSE THE WIRE NO MORE THAN 6-10 INCHES FROM THE POWER SOURCE!!!! I can't stress this enough.
Old 07-01-2004, 01:58 PM
yakk's Avatar
Re: Re: Running Power to Truck Bed
It's an 04 Z71. It has the plug for a trailer, but I dunno if this includes a brake?
