Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-29-2004, 03:37 PM
negativecreep934 negativecreep934 is offline
Question Drain Plug location
Hi I have a 1991 Camry 4-cyl and wanted to do a flush of my coolant system. I know where the radiator drain plug is but I can't find the engine drain plug to drain the coolant out of the engine. Any information on where it is located would be greatly appreciated.
Old 06-30-2004, 01:07 AM
Joe W Joe W is offline
Re: Drain Plug location
Not sure where it is on the '91,but if your going to do work on this I would recommend a Haynes or Chiltons manual.It will have this info and alot more.About $15 at any larger parts store.
Old 06-30-2004, 11:03 AM
stanleyeye stanleyeye is offline
I have 98 camry 4-cyl, the location of the drain plug is on the bottom of the engine, the left side of the oil pan. I am not sure it is same as the 91 camry.
Old 06-30-2004, 11:25 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
If oil comes out, you've got the wrong plug.
Old 07-02-2004, 04:10 PM
GSS123 GSS123 is offline
Look just to the left of the oil filter. You may not be able to see it but you should be able to feel it. Put some antiseize on the plug before reinstalling. BTW they are very hard to turn out the first time.
Old 07-03-2004, 01:07 AM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
If I'm not mistaken, I do believe they are to the right of the oil filter on the 5SFE, rather than the left.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 07-04-2004, 06:21 PM
Brian R.'s Avatar
Resident Chemist
Teflon tape is an good alternative to apply to the threads of the drain plug.
Old 07-04-2004, 06:42 PM
I can honestly say that I've never thought of using teflon tape on drain plugs, but it actually sounds like something to start doing. Would this be an alternative to Anti-Seize compound, or could it be used with the compound?
Old 07-04-2004, 07:01 PM
Brian R.'s Avatar
Resident Chemist
The teflon tape is used by itself only when the threads are the sealing surface. If there is a gasket, then use antisieze and no teflon tape.
Old 07-04-2004, 09:51 PM
I see...thanks for the tip Brian...I'm going to have to try that...
