Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 06-29-2004, 02:50 PM
dworakow dworakow is offline
pwr window not working
Passenger side power window in my 2000’ Venture suddenly stopped working yesterday. Clicking both master switch and the other one on the passenger side doesn’t help. Driver side pwr window works fine.
The broken window is closed (thanks Good!) so I can drive for a while. My worst fear is that I need the replace a window regulator which is quite expensive.
Is there any other part/problem besides the broken power regulator that could create the window malfunction?
I read something about melting switches on this forum but I would be surprised if two of them (passenger and driver side) went bad at the same time.
Greg
Old 06-29-2004, 07:28 PM
hockeyfan_019 hockeyfan_019 is offline
Because of the way things are wired, only ONE of the switches needs to go in order to kill the window control... Just hope it's the pass switch, cause the stealership just hit me for $68 for a driver side "master" switch... I actually SAVED $10 by getting quotes from 2 dealers... $68 was the CHEAPER price!
Test the pinouts on the switches before doing anything dramatic. It's likely a master switch like mine, but it is POSSIBLE that BOTH of the actually ARE defective, or there is a broken ground wire. Nice design, it puts the switches in a place where if the windows are left open, rain comes right down the inside of the door, saturates the switches, and then they fry...
Good luck!
Tom
Old 06-30-2004, 10:21 AM
Thumbs up Re: pwr window not working
Tom,
Thank you for the tips. I will definitely check the switches and I will let you know about the outcome.
I think this forum is a great place for people looking for troubleshutting advices.
Thanks
Good luck!
Tom
Old 06-30-2004, 11:52 AM
gadan gadan is offline
Re: Re: pwr window not working
Originally Posted by dworakow
Tom,
Thanks
I didn't know that very descriptive
My problem is that the window open and close from the passenger side, but won't open from driver's side, it will close but won't open. Any ideas?
Old 06-30-2004, 12:28 PM
Arrow Re: Re: Re: pwr window not working
Hi,
I saw some posts reporting the problem you mentioned. You can find the on the following forum:
http://forums.vmag.com/mvventure1199/
There were also some tips how to fix it.
Good luck
dworakow
Old 06-30-2004, 02:42 PM
Thank you, I checked in the forum but did not find exactly the same problem. I'm going to check again tonite...
Thanks again...
Gabe
