Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 06-29-2004, 02:21 PM
adc87005 adc87005 is offline
Help!! Tranny Problems!
I have a 94 Ford Ranger Splash 2.3L 5speed manual. It had been sitting for about 2 years and it was wrecked (front fender/headlight) . I got to the point to where i can start it up and it runs great but there is a problem with the transmisson. i cannot shift into any gears when i try to shift into reverse it makes a horrid noise. i bled it and bled it thinking that was the problem. But I am thinking that its the slave cylinder. I was wondering if anyone had any links or info on how to replace the slave cylinder or how much it would cost to have a transmisson shop do it. Or if you think its something else all information would be apprecated.
Thanks
Old 06-29-2004, 06:54 PM
Re: Help!! Tranny Problems!
please
Old 06-30-2004, 08:45 PM
you all are all assholes... 19 people looked at this and not one of you repied
Old 08-05-2004, 10:30 PM
graphicassult's Avatar
graphicassult graphicassult is offline
Send a message via AIM to graphicassult Send a message via Yahoo to graphicassult
Dude chill out, its possible that you have a linkage problem to your damn tranny. Or possibly since its BEEN SITTING FOR 2 DAMN YEARS that its started to rust or corode in the tranny which has destroyed the gears. Your probly lookin at a new Tranny.
"All right Ramblers, let's get ramblin."
Old 10-02-2004, 12:33 AM
purgatori78 purgatori78 is offline
Hrm, well I have a 94 Ford Ranger XLT, 5-speed, and mine is doing the same thing. The only difference is it started doing this yesterday and mine hasn't been sitting for any extended period of time.
Old 10-03-2004, 12:32 AM
trannyman52 trannyman52 is offline
is the pedal mushy,,,,or stiff ??????
mushy,,,you did a poor job of bleeding,,,or upper cyl shot,,,possibly a clutch
stiff,,,,ya need a clutch !!!!!!! probably
Old 10-25-2004, 10:10 PM
[email protected] giczei@aol.com is offline
I replaced the clutch in my '95 S-10 and was careful to follow the instruction manual regarding the hydrolic clutch cable and cylinder. Still after the job was done the I could not push down on the clutch pedal to shift. I had to get the hydrolics anyway. It was only at $75. But, those things sure seem delicate. Gimmie the old metal linkage I can understand and adjust...
Old 10-29-2004, 02:34 PM
sp3edr4cer sp3edr4cer is offline
ok if you are going to replace the slave sleeve it is easy. y9ou have to slide the tranny back. in the bell housing there are 2 or 3 bolts (cant remember) you pull those out remove the two hoses from the outside of the bell housing that is attached to it and then ****$*# blead the slave sleave with a pressure tank before sticking it in or have fun doing it after it is in***$*$*%% then you just slide it all back in place
