Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-29-2004, 12:21 PM
hypodermic hypodermic is offline
Post Fuel Leak
I've got an old 86 cutlass that I drive around in the fields. It's got a tiny pin hole leak in the gas line so I was woundering if anyone could tell me a quick easy way to patch it... I don't take it on the roads so I'm not goin to be taking it to a dealerships so....
any suggestions?
Old 07-01-2004, 09:53 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: Fuel Leak
Get you a fuel rubber hose which has a inside diameter that is the (same or close) of the outside diameter of the fuel line.
Cut about 1 inch length of the fuel hose and then cut it vertically so you can slide the fuel hose aroud the fuel line. Use a screw type to clamp the fuel rubber hose and tighten it up.
