Old 06-29-2004, 10:17 AM
jerrylittle jerrylittle is offline
ebay's air resistor!
Has anyone bought one of those resistors that change the motor into thinking it is getting cold air? Please give me info if you have please. Not your thoughts but experience. Thank you.
Old 07-03-2004, 07:42 PM
TweakedGM TweakedGM is offline
Re: ebay's air resistor!
If the resistor is more than 50 cents don't buy it. If you want one just go down to the radio shack and buy one that has 1/4 or 1/2 watt resistor. No same resistor value works on all vehicles.It does work maybe give you 6 to 10rwhp.they are primarily used at the track only.
Old 07-03-2004, 08:04 PM
Puffnstuff's Avatar
Puffnstuff Puffnstuff is offline
Send a message via ICQ to Puffnstuff
All you're doing is changing the signal being sent by the air temp sensor to the ecm so that it thinks the air is colder than it really is. In return it will richen up the mixture which is supposed to make more power. It will probably end up creating excess wear with the unburn fuel in the cylinder. On the 99+ ls1 based engines the air temp sensor is in the maf but I forget which wire it is in the harness.
06 Toyota Tundra Double Cab
Old 07-03-2004, 08:58 PM
Re: Re: ebay's air resistor!
question you said a 1/4 or a 1/2 watt resistor but with what kohm? The ohm rages are big. thanx.
Old 07-03-2004, 11:37 PM
use what they are using 475 ohm.I wouldn't want to put one in, for the reasons Puffnstuff gave.
Old 07-04-2004, 12:01 AM
Warning to customers:
Please do not attempt to purchase the part from a hardware or electronics store and install it without our directions. Incorrect installation, resistance value or heat capacity could cause damage to your electrical system.
Old 07-04-2004, 07:02 AM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
dont get them, their junk, i had a costly repair cuz of one
Old 07-04-2004, 09:45 AM
What happened to your vehicle?
Old 07-04-2004, 10:19 AM
well i ordered one i got it, i liked it but when i took my truck in for a check up i took the basterd off and then my truck was never the same, had to get a tune up, and all kinds of things, over 700 dollars, their junk
Old 07-04-2004, 10:35 AM
But it did not blow up any electronics did it?
Old 07-04-2004, 04:06 PM
it burned up the tps, and mfs, because when i returned it to stock it surged the whole truck and i dunno what all it did i just knw that the dealer said they get these about 2 or 3 times a week when people throw those junk chips in and restore it to stock it just burns up alot of stuff
Old 07-04-2004, 04:07 PM
their junk dont get them
