Old 06-29-2004, 09:17 AM
GMAC454 GMAC454 is offline
Smile wiper, dash lights, security, etc.. fix!!!!
hey everyone with the "ghost in my wipers", and "they will run when i push the squirter button but wont run on delay or hi/lo", and will not work on intermittent, dashlights doing funny stuff, etc......
I have been thru everything in the entire wiper system.
tore the motor out regreased and cleaned all connectors and electrical pickups, replaced and tested all relays under the hood, checked and replaced all fuses, replaced the 80.00 dollar multi-switch.
NONE of these things fixed the issue and are not the problem.
The fix is the BCM - Body Control Module. this little beast of a circuit board does just about everything !!!!! it controls your security system if you have one, it controls the rear wiper, the front wipers and all the related delays, the security system, elect locks, etc.... and electronic signaling associated with this stuff. I have gone thru the entire electrical schematics on this thing. the module is about 385.00 bucks. Ouch! thats alot just to fix your wipers, or headlights.
But what i did was call a reputable auto salvage yard and had them do a computer search for my make and model '96 grand caravan for a BCM. they found one without issue and it was 100.00 bucks including shipping. some of the BCM's need to be programmed (flashed) by the dealership this is about 65.00 bucks. but i know for a fact that the '96-'99 are plug and play no flash required. i pulled my old one slammed the new one home and "click" the wipers work perfect!!!!!!!!!!!!
the BCM is located under the dash on the drivers side right behind the fuse plate. it is fairly easy to get out. there are just a few 9 or 10mm bolts that hold it in place and then it slides up on a couple pegs and the bolts just hold it in place. look at the one you picked up and you will see where the bolts are. dont forget the very top one toward the driver door, you will need an extension about 8 inches to get it. also if you remove the code testing plug-in that sits under the lip of the dash it will save you a few scars (believe me) the screws protrude right where you will be snaking your hand up and through. I feel it is a simple fix and the only criteria for ordering are if you have security and power locks or a combo of them. your just wasting money if you take this issue to a dealer. hope this helps you save some money doing it.
thanks
GMAC454
Old 07-05-2004, 06:34 AM
hooba hooba is offline
just when you thought the gremlins were winning, thanks brother
Old 09-13-2004, 12:35 AM
wahoo75 wahoo75 is offline
Re: wiper, dash lights, security, etc.. fix!!!!
which auto salvage yard did you call ? thanks.
