Old 06-29-2004, 02:21 AM
MsPebbles MsPebbles is offline
Send a message via AIM to MsPebbles Send a message via Yahoo to MsPebbles
Angry blown coil pack
Hello I have a 91 buick park ave (3800), and I have replaced the coil pack at least 4 times they keep blowing out. The spark plugs has carbon on them. I am tired of replacing these coil pack what cause them to blow out like that? need more info let me know thax.
Old 06-29-2004, 07:50 AM
84fiero123's Avatar
84fiero123 84fiero123 is offline
Re: blown coil pack
you dont say if these are new gm, aftermarket, or junk yard coil packs
Old 06-30-2004, 10:05 PM
PAman PAman is offline
Re: blown coil pack
What test did you use to determine they were bad? Make sure by removing the 2 wires attached to 1 segment at a time, start (or attempt to) and watch the spark jump across the open terminals. If all three segments do this, the coil pack is probably good. If good, measure resistance in your plug wires, check the coil connector, replace spark plugs, etc. Plugs and wires are cheap, install proper replacements and reduce possibilities.
