Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 06-29-2004, 01:17 AM
RtMangler RtMangler is offline
Send a message via AIM to RtMangler
Exclamation y so slow?
Anyone have any clue y i would be runing in the 17's i ran my car at least 10x last wensday and it just dont wanna go any faster it even feels slow no matter wat i add
i got ------ Mopar performance ECM
Ice man
thermal muffler (switching to canister in few days)
performance under-drive pulley
4-1 header
high flow cat.
10.3mm plug wires
screamin demon coil pack
short - throw shifter
shaved head ( last year)
think thats about it but still it shouldnt be in the 17's should it lol
i did a compression test today highest piston was 162 lowest was 149 but thats fine there 15% of eachother the damn car has 145k miles on it but has no problems wat so ever runs like a champ but just slowness if have any idea pleaze post... would help me out alot!
Old 06-29-2004, 12:27 PM
Beastiek2's Avatar
Beastiek2 Beastiek2 is offline
Banned
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
Re: y so slow?
and what year is this car?
Old 06-29-2004, 01:19 PM
its a 98 Neon R/T 4door.....
Old 06-29-2004, 01:49 PM
Dropped2KNeon Dropped2KNeon is offline
Send a message via Yahoo to Dropped2KNeon
Re: y so slow?
id have to see you race to see what you might be doing wrong, maybe you're double shifting, or shifting too early.
Old 06-29-2004, 02:41 PM
i tryed everyway of shifting from normal shifting to not using the clutch from shifting at 6k to shifting at 7200k, i dont know lol could something in the motor be slowing the car down some lil piece that when it gets old needs replaced?
ill take pictures of the motor and stuff lol just to get a glimpse
Old 06-30-2004, 09:38 AM
Pedros91 Pedros91 is offline
Send a message via AIM to Pedros91
Re: y so slow?
what rpms are you lanching at . the more you spin your tires the slower u go
Old 06-30-2004, 02:36 PM
209 neon's Avatar
209 neon 209 neon is offline
Re: y so slow?
Ice man
4-1 header
high flow cat.
10.3mm plug wires
please tell me your not serious , I have a single base line 95 and Im clocking 14.5 with minor bolt ons and still can smog with everything I have its not the fastest neon but your definately doing something wrong if your trying to hit 17s dear lord
STOCK MOTOR 14.5 with minor bolt-ons:
ICEMAN COLD AIR INTAKE
HEDDMAN HEADERS
CATCO HI FLOW CAT W/STOCK 2.25 PIPING
TTI RACE PULLEY
APEXI N1 EXHAUST
MSD COIL
MAGNACORE WIRES
ENERGY SUSPENSION MOTOR MOUNT INSERTS
NO POWER STEERING UNIT/ NO A/C UNIT
"RACE ME IF YOU WILL BUT REMEMBER IN THE END ITS STILL JUST A NEON"
Old 06-30-2004, 08:40 PM
i shoot off at about 5500 rpms but i dont drop it tahts the worst thing you could do cuz thats wheel spin out teh ass... i just let it out slowly off the last yellow light and then bam im gone but could motor mounts be slowing me down that much i know there bad just for the fact u can feel the motor move wheen u let off the gas pedal theres no broken motor mounts yet but if i do drop the clutch dear god i have wheel hop most of the way thru first gear depending on when the tires feel like grabing lol but still thats 17's motor mounts shouldnt slow me donw that much should they???? possibly...
Old 07-01-2004, 08:30 AM
209 neon's Avatar
Re: y so slow?
well I have energy suspension motor mounts and I still get wheel spin in first with out launching and half through second but it will help your ets alot if you have them in expecially when you combine them with the afx bobble strut then your motor wont move worth of crap and you will have more power to the ground. but launching at 5500 is just way to high if your not running on slicks..... try 3000 and dont punch it until you gain traction thats what I do
HEDDMAN HEADERS
TTI RACE PULLEY
APEXI N1 EXHAUST
MSD COIL
MAGNACORE WIRES
Old 07-01-2004, 12:07 PM
okay well i ordered the prothane motor mounts from modernperformance.com and i ordered the solid af/x bobble strut from howellautomotive.com hopefully that might help a tad how bad is the vibration with the af/x bobble strut?? think all this motor mount crap will even help? i hate money lol it always goes away 110.00 worth of plastic motor mounts and a steel rod LOL
Old 07-01-2004, 03:40 PM
Re: y so slow?
well ok your crazy don't launch so high
Old 07-01-2004, 03:48 PM
Re: Re: y so slow?
thats still too high to launch at unless you have slicks try to launch at lower like 1.5k or 1.8k at the most. u want no wheel spin the more wheel spin the slower u will go I know it sounds crazy but just give it a shot
Old 07-01-2004, 10:38 PM
FuriousMachine95's Avatar
FuriousMachine95 FuriousMachine95 is offline
Send a message via AIM to FuriousMachine95
Re: y so slow?
It's gotta be something you are doing. Port and polish your headers. That will help your time too. Maybe you need gaskets and berrings replaced too if you have not had them done before now.... Motor mounts will help big time on wheel hop. Wheel hop is bad. Very bad. Check for vacuum leaks. That might be a factor too. If you havn't already, take off your power steering and A/C belts before you run. They take up valuable hp. Some weight reduction wouldn't hurt either.
Acting my age is no fun.....
Old 07-02-2004, 11:13 AM
209 neon's Avatar
Re: Re: Re: y so slow?
thats too low 1.5 or 1.8 jezzzzus I know cars that idle higher than that if you launch at ; those rpms guaranted bogging buy if you launch at 3000 with out going full throttle until traction gained you will be fine, I launch at 2500 on the street dump the cluctch and floor it and I do fine, but on track its more slick so you would have to play with it alittle
HEDDMAN HEADERS
TTI RACE PULLEY
APEXI N1 EXHAUST
MSD COIL
MAGNACORE WIRES
Old 07-03-2004, 06:57 AM
Re: y so slow?
If you launch at 1.5 or 2 you need to ease out the clutch and roll into the throttle as your launching. That will help keep from bogging down and will keep wheel spin down.
