| Suspension setups, shocks, springs, tires, handling. |
comes on and off. When I start and go it stays on and sometime goes off while driving. Or if I drive to the store go inside come out start it up the light is off.
What gives... Any thoughts Or is it the I need brakes soon light? Thanks
Joe aka 240ztt '71 240Z HLS3020425 '79 810 KHLG810000299 '94 XE P/U 1N6SD11S6RC345206 '03 XTerra SE/SC 5N1MD28Y73C697225 '03 Honda Insight JHMZE14793T000067 *nothing but Nissans in my garage* *so what If I have a Hybrid* |
check your brake fluid reservior, it comes on and off when your press your brakes and the fluid goes from the reservior to push the pistons so the fluid level fluctuates up and down, telling the sensor to turn the light on and off.
fluid level is fine.
like I said it only comes on when I start the car (intermediate) It can stay on when I drive to work in the morning. I can stop for coffee get back in and the light is off... I haven't changed the brakes since Summit Point last year maybe thats it...:o
I have a similar problem, my brake light comes on under moderate acceleration and may shut off when I brake hard. Sometimes it just stays on. I havent checked it out, but Im guessing I have a bad switch or something, im just too lazy to check it out.
P@ - www.customsteel.com Red 99 G20(t) / UR 2 piece / JWT POP / HS CAI / WW Lip / HS Header / Greddy Evo / S3 cams |
I'll do the brake job and see what happens. I'll keep you posted
Thanks
I had the same problem and Infiniti finally fixed it after them saying "cannot duplicate problem" when I brought the car in. Turned out it was some loose change had fallen into the e-brake and was keeping the lever from completely closing.
Thanks everyone..
Turned out brake fluid was a *tad* low guess the switch is really sensitive... Duh :silly2:
had that same problem a while ago, told you
your the man...we all know. It was a hair under the max line..
