Old 06-29-2004, 12:38 AM
bigbobswagon bigbobswagon is offline
fuel guage problem
I've got a "86 with the MT5 cluster...tach and all . The fuel guage is past full by a quarter of a tank...I changed the cluster only to have it jump in the same place All the guages work except the #$%^gas gauge any ideas of the problem? BTW I just got it from an estate sale and it seems to be in great shape...I just don't want top run out of gas
Old 06-30-2004, 02:25 PM
sahib sahib is offline
Re: fuel guage problem
Have you checked the sender? This would be a part of the in tank fuel pump assembly and would require a fuel tank drop, probably. Don't know what the correct readings should be but I would think somewhere in the 0 to 100 ohm range. I believe 0 ohms (on a VOM) would be empty and the higher resistance would be full or not empty depending on the fuel level in the tank.
Old 07-04-2004, 01:48 PM
Thanks for the reply, One out of thirty visits to the thread with a reply(?) Will check the reading at the sending unit....Thanks again
Old 01-14-2005, 07:43 AM
ozziefive ozziefive is offline
I had that prob with my 00 ford taurse it was a sensor behind the dash not sure what its called but it drove me nuts . replace it at a dealer no prob sence
