Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 06-29-2004, 12:26 AM
jpac1 jpac1 is offline
rpms when idling
I have a 1991 gmc 4x4 with the 350 and 400,000kms. When I am in drive it idles at 200 - 300 rpm. Is that low? Now my question is that when in drive and sitting at a light or in park when the engine is hot my rpms drop to 150 and goes to 350 up and down as if it is surging( for a lack of a better word). When i am driving the rpms are fine, about 1100 - 1200. Any ideas as to what my problem could be? I read another thread about someones throttle body sticking, could this be my problem? If it is are theyhard to clean yourself? Thanks in advance!
Old 06-29-2004, 01:04 PM
formulaross formulaross is offline
Re: rpms when idling
I suggest getting a second tachometer and checking the accuracy of your tach. 200-300 is VERY low, and I wonder if what you are getting is an accurate reading. Your engine is computer controlled, if I recall correctly, and idle speed is controlled by the computer via the air bypass solenoid. It and the throttle body can be cleaned with Gumout, etc. Be careful, there is a mass airflow (MAF) sensor among the hardware, and possible other sensors, that you need to be gentle with.
Old 06-30-2004, 07:04 AM
fast6's Avatar
fast6 fast6 is offline
I'm having the exact same problems with my 1990 305. It idles very low and surges. I am going today to check the egr valve.
I would suggest to you to look for vacuum leaks, run some injector cleaner through, check all ignition parts, change fuel filter?, check timing, may need valve adj. or have a bad cam lobe...just some ideas. Good luck.
Old 07-01-2004, 07:23 PM
TweakedGM TweakedGM is offline
the 91 gmc it surged every once and a while. I changed the plugs to a racing plugs worked good,6 months later it happened again. I figured it worked once try again checked the plugs two where misfiring the I when the bosch plugs worked fine.Then about a 6 to7 months later did it again, same problem as the first one. Then I went and got factory plugs not a problem.
Old 07-02-2004, 03:39 PM
fast6's Avatar
Well I changed the EGR valve and WOW!!! what a differance. The truck now idles at the proper rpm, it runs smoother and is all in all much nicer to drive(smooth).
