Old 06-28-2004, 07:31 PM
jmob jmob is offline
help with my 94 camaro!
does anyone no what causes my 94 camaro to rough idle? when i stop at red light 4 a long time, my car seems to shake! and it feels like its gunna die. no gauge lights go on to remind me of a serious problem. should i worry about it? ive change the alternator , o2s , plugs and wires, pcv and all fluids seem to be full. i also check for leaks, seem to be find! yeah its a v6 - 3.4 just got to a 100,000 miles
Old 06-28-2004, 08:18 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: help with my 94 camaro!
could be a bad injector, or a failing IAC valve, clogged fuel filter, or worse case a bad fuel pump. id do the fuel filter and go from there.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-28-2004, 09:21 PM
thanks for the info , i no how to replace the IAC valve. but not the fuel filter or injectors. got to read up on it
Old 06-28-2004, 09:22 PM
nic pics
Old 06-29-2004, 01:53 PM
just change my IAC valve. still a rough idle. i guess the fuel filter next
Old 06-29-2004, 07:42 PM
89IROC&RS's Avatar
thanx man, they muh girls, lol, sorry to hear i gave bad advice, but unless you got a way to diagnose, kinda gotta go one peice at a time.
Old 06-29-2004, 11:36 PM
spikaronie spikaronie is offline
Lets see a couple pics of your car jmob.
Old 06-29-2004, 11:37 PM
na bro you didnt give bad advise, im glade you wrote back with some info! the IAC was caked with black sh*t , i took it off and sprayed it down with carb cleaner. i also sprayed the housing! it seem to idle a little better. well the car just seems to shake at red light. not that bad though, but enough to pizz me off!!!!
Old 06-29-2004, 11:40 PM
spikaroni what kind of car do u own?
Old 06-29-2004, 11:45 PM
Chevy Berreta GT.
Old 06-30-2004, 08:27 PM
Old 06-30-2004, 09:25 PM
89IROC&RS's Avatar
they sell body kits for berettas???????? to be honest, that dont look all that bad, zat got the 305 in it??? im thinking alot of potential there.
oh and if the IAC was caked with black resin, i highly reccomend an induction service, either jackobs or BG depending on where you live and all. i did it to my IROC and it made a major difference, cuz she hadnt had any service in 14 years lol.
Old 06-30-2004, 10:18 PM
how much would an induction service cost? and what will it do? have you ever heard of a cleaner call sea foam green, some one said it cleans out injectors , and some other stuff to help a shaky idle! should i try that? hey, i just bought a haynes repair manual it tells alot of info on my 94 camaro! but i think a found a mistake all ready , should i trust this book? in chapter two theres a diagram of a 3.4l engine cylinder coil terminal locations and i looked under my hood and its a little different; well wires 1, 3, 5 goto the left bank "driver side" and wires 2, 4, 6 goto the right bank (under my hood). in the diagram it looks like 1, 6, 5 goto the right bank and 2, 3, 4 goto the left bank "the driver side" i hope this dont confuse you . i guess you just goto see it. page 2A-1 of the haynes repair manual . anyway from the picture, my wires 3 and 6 are backwards. whos right does anyone no? if mines wrong my car still run pretty good!!! should i change them? will the mess my car up , maybe thats why my run a little shaky!!!
Old 06-30-2004, 10:22 PM
If you put the plugs on the wrong wires you are in some big trouble.Its spose to rain tomorrow night last chance for mornin.
Old 06-30-2004, 10:33 PM
89IROC&RS's Avatar
um, i thought your car was running rough???? crossed plug wires would do that. set up your wires the way the maual says, and see if the rough idle goes away.
